- Reaction score
- 747
Yeah, missed location, oops!
Discuss Adding RCD to existing installation - what options are now allowable? in the DIY Electrical Advice area at ElectriciansForums.net
The MWC was for repair of a ring main following a fuse blowing, apparently a fault in a junction box, also replacement of two sockets with faulty shutters. The certificate doesn't detail the exact works, only the fact of the repair and test results following the repair (insulation resistance and earth fault loop impedance).It sounds to me like this outfit have used an old Minor Works Cert dating back to the 16th edition and therefore not valid. What repairs have been carried out that are noted on this cert btw?
Old software? It looks like the form was filled in on a computer and then printed, not typed into an existing printed form.Nice. So that's definitely an old cert.
Thanks everyone. The work was done for us, but sub-contracted by the firm that was doing some building repairs. The CU replacement was his electrician's recommendation following a visit to repair a fault.
Is it quite clear that a CU replacement would need to include RCD protection in order to comply? I wasn't sure on that, after all replacing fuses with MCBs is a step in the right direction even as it stands. It would be helpful if you could point out some regulations to that effect.
Thanks, Tony S
The quote was in writing, but didn't give enough detail in hindsight. I can't tell you how much I'm kicking myself for not dealing direct with the electrician. I should have learned my lesson by now regarding subcontracted work, but the temptation to deal with a single party is always there. Of course the quote didn't say that the installation wouldn't (or couldn't) comply with current standards so I hope that gives me some leverage.
Agree, I could well be *****ed. From memory the invoice was along the lines of "consumer unit replacement as quoted", I wouldn't expect any more detail on a fixed price invoice. The detail should have been on the quote, but we are where we are as they say. My plan I think is ...Oops.
Reply to Adding RCD to existing installation - what options are now allowable? in the DIY Electrical Advice area at ElectriciansForums.net
