Search for tools and product advice,
Discuss Adding single pole switch in the UK Electrical Forum area at ElectriciansForums.net
I am trying to install a new fixture and want to bring power to it by adding a single pole switch to a box containing another single pole switch. I believe its the end of the circuit as both black and neutral wires are hot. How do i add the new switch to it? I made pigtails, ran them from the black feed to each switch, joined the neutral from the feed and the neutral coming in from the fixture, and hooked the black coming from the fixture to the available post on the new switch. Im getting power at the fixture, buts its not working or the light doesnt turn on. Have i made a wiring mistake or do you suspect there is a problem somewhere along the circuits line?
If you only have one black and one white the white is not likely to be neutral but a hot return.
Reply to Adding single pole switch in the UK Electrical Forum area at ElectriciansForums.net
I have 2 kitchen lights, each on its own switch. I would like to re-wire them to where the first switch turns on both lights, but where if the...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
Hello Forum! The building I maintain has some fluoro fixtures with battery backup ballasts. There is a 3-way switch at each end of the hallway...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
