R
rdautobody
ok so to cut a long story short I had to buy another air compressor as my one was giving up and being used in a bodyshop it was essential that i replaced it.
anyhow my old compressor was single phase so was simple plug in and air was made
the new one i have here is unfortunatly not as simple.
its a 3 phase supply and the 3 lives and earth going in are all colour coded and fit perfectly, however there is one issue here,
there is 4 wires that are loose in the switch box that mount on the wall,
I have traced the wires and one of them is the live (brown wire) from the on/off swtich on the compressor it self
the second wire is the live ( brown wire) from the release valve on the end of the compressor.
the third wire that is loose is a blue wire with red tape on ( i would assume is a live???) this comes from the bottom of the reset switch
the last wire that doesnt have a home is the blue wire neutral from the release valve.
I am completely baffled as i cant see for love no money where they go or where they came from,
the two brown wires from the on off switch and the release valve were loose and just pushed into the switch box, the blue neutral wire from the release valve along with the blue wire from the bottom of the reset switch were poking out of the top.
Any help will be greatly appreciated as the bodyshop has come to an absoloute standstill!
ive had two electricians come out and said it was easy but neither returned
