Discuss Alarm cable at cu in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
andyd55
Hi all,
Have recently moved into a new build house which has been wired for alarm system throughout. however there is one alarm cable (6core) which is by the consumer unit, can anybody think what this is for or shed any light on why you would want a alarm cable in cu?
Not knowing the layout of the house or where the CU is... Is it for the keypad?
could be that they've used the alarm cable to supply mains to the alarm. seen that before now. a whole estate of new builds.
If 's new build then I would be asking the company that built them to find out. Daz
Either way if this cable is Band I and is run along or in containment with Band II cables it contravenes BS7671 and should be addressed.
I wouldn't be cutting it off. If nothing else there may be 12V feed connected to it and you may pop the fuse. Have a look in the alarm panel and see where it is connected to. May be to a spare zone and they forgot to route it to a sensor. Daz
Reply to Alarm cable at cu in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
