Discuss Am2 fault finding in the UK Electrical Forum area at ElectriciansForums.net
Sam4365
Can a get some tips on the am2 fault finding.
1 fault that was on my list was chattering on DOL motor unsure how to find the fault.
Chattering on a contactor normally indicates that the power supply has been wired through a NC contact rather than a NO contact so that when power is applied to the contactor the NC contact opens and switches the power off, so the NC contact then closes which switches it on again and so on.
Reply to Am2 fault finding in the UK Electrical Forum area at ElectriciansForums.net
I have recently taken on a lecture role at a local college. Their facilities are in ---- state. My aim to rebuild/build a comprehensive fault...
Hi all, I completed my level 2 2365 installation and my level 3 8202 advanced technical diploma in electrical installation and I’m unsure on...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Fault finding- does any one know how many faults out of seven you need to find to pass the AM2S fault finding section ? any info would be helpful...
Hi I'm trying to find if I have a fault in these to brakers of in the lines. The 32A braker leads as far as I know only to a junction box that use...
