Discuss Amendment 3. Non combustible CU in the UK Electrical Forum area at ElectriciansForums.net
Am I the only one confused as to why the CU is meant to be metal but the switchgear is all still plastic?! I mean what's the point??!!
The intent of Regulation 421.1.201 is considered to be, as far as is reasonably practicable, to contain any fire within the enclosure or cabinet and to minimise the escape of flames. That's why you also have a metal flap covering the MCB's, etc.
Eddie this topic has been done to death on here for last couple of months! Do a quick search mate. :smile:
Put a wylex one in the other day.....probably a good thing it's metal clad after all the product recalls wylex have had over the years lol.
Not seen the Wylex one before. That flap could have been designed to look a lil nicer I think. But, haha, yep maybe non combustible is a good idea for Electrium brands!
Yes this has indeed been done to the death, however for the avoidance of doubt for a consumer unit to be compliant with AMD 3 the enclosure does NOT have to be steel or metal simply "made of material that does not burn if exposed to fire"
This is the rest of the house. Inside snaps are of the show home. All 9 houses are the same and are up for 3.3 million each!
Edit: excuse the fingers in one of the shots.
Reply to Amendment 3. Non combustible CU in the UK Electrical Forum area at ElectriciansForums.net
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
We were all told that SPD's were mandatory under A3 from September last year and even sat through the webinar spelling it out. I work an area...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
One of our contractors has identified a concern with multiple showers on a single 100 amp supply.(unsure how many yet i have asked for further...
