La Poste
- Reaction score
- 126
Greetings.
If I want to wire a standalone RCD underneath the main consumer board I need to take a separate supply to cable to the RCD. I would take this supply from the outgoing side of the main switch in the consumer box. These supply cables would then enter the enclosure of my standalone RCD and act as incomers. I was thinking of using 4mm cable and a 23A RCD.
Is there anything wrong with this method?
Also I was wondering if anyone could recommend crimps I could put on the end of the 4mm cable so that when I bring the cables into the outgoing side of the main switch it is all nice and neat. You know like spade crimps, rather than just shoving the cable into the terminal I think it would look much better and be a better joint too.
Cheers.
Cheers.
