Search for tools and product advice,
Discuss anyone come across this before.... in the Electricians' Talk area at ElectriciansForums.net
Has anyone come across this one. situation new build bungalow, external timber framed walls are covered with a metallic damp proof membrane, metal boxes attached through DPM to dwangs then walls have been framed and drywalled. the problem is the earth continuity between any circuit that has been installed on the outside walls is short circuit (>0.2ohm), any views or comments
i think he means that the metallic membrane is causing a s/c between the back boxes of different circuits. in that case, should have used dry-wall boxes.
edit: @OP. what are dwangs???
your right telectrix i did mean a short circuit between the back boxes of different circuits, job is now finished and ive just been sent to test it. dwangs are the bits of wood installed to give a fixing for metal boxes. and believe it or not there is plastic conduit drops. what do you suggest, does it comply or not
well, they're all earthed back at the CU, but testing would be a problem. perhaps E54 has some ideas here, as long as it's not TT. LOL.
soz its a tnc-s system although no meters have been fitted yet. I've just been doing the initial verification. From the stories on site this build has been a farce form the start.
Reply to anyone come across this before.... in the Electricians' Talk area at ElectriciansForums.net
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Just interested in peoples thinking on using the neutral through the earthing system like I came across today. I've come across many wrong...
