Discuss BACK DOOR SECURITY LIGHT in the Lighting Forum area at ElectriciansForums.net
Hello can anyone advise me on this please...
My mum wants her back pathway lit up and was gonna get a battery operated Mr Beams light. I wondered could I just put a security light on the main wall attached to the house and run the cable straight to the consumer box as I would only have to drill through one wall to get to it and would probably be a lot brighter for her. I've heard you need use armoured cable but I don't see why as the light will be under a roof shielded from rain and wouldn't be any wire on the floor...it's literally 1 light going through 1 wall to the consumer box inside the house...
Thanks any advice appreciated ...
Neil
That would be classed as adding a new circuit and would fall under part p of the building regs and require a certificate
A cable that could stand up to UV would be ok.
I know it not the best/cheapest solution but could you not get an electrician in to fit you one?if it is as easy as you say then it would cost around £40 i recon
Many DIY'ers would drill through wall and then plug light in to an existing socket, really advise not to add to consumer unit due to risk
Neil
Just put a plug on the end of a security light and plug it straight in you mean...never really thought of doing that...cheers
if you are doing that, fit a 5A fuse in the plug, and use black flex. HO7RN is favorite.
Reply to BACK DOOR SECURITY LIGHT in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
