Discuss ballasts vs emergency lighting module in the Industrial Electricians' Talk area at ElectriciansForums.net
S
smp
Hi,
I have some 4 pin 28w 2d emergency fittings that are not working properly, consisting of electronic ballast and then em module. Is there any way of detecting which unit is faulty as with the light operating ok in normal mode,I changed the module first as the fitting wasn't operating on test, but the fitting still isn't working, so now assume it's the ballast (cheap moulded unit with fixed leads)
Any help would be appreciated as I have around 60 of these fittings to look at!
Regards,
smp
Reply to ballasts vs emergency lighting module in the Industrial Electricians' Talk area at ElectriciansForums.net
Hello gents I'm just after some clarification, I have a kitchen light fitting that uses a 2D 28W compact fluoresent lamp that I'd like to...
Hello Forum! The building I maintain has some fluoro fixtures with battery backup ballasts. There is a 3-way switch at each end of the hallway...
I want to operate 3 lighting set up using metal halide lamps for studio works or cinematic projects in the future. as of now i have got two...
Hi all, I've been having some issues trying to fix a fluorescent light in the bathroom. Here's the steps I've taken so far after it suddenly...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
