Discuss basic outside light wiring help in the UK Electrical Forum area at ElectriciansForums.net
hey everyone,
hopefully a very straightforward question please can you advise on the following
have a mains wire ready for outside light (previous owners had light but wasn't working) tested wires and are live.
out of wall have red black earth from mains, far as i can tell not linked to a switch inside anywhere.
i have attached these per the pic to the new outside light board.
red to live, black to neutral, earth to earth.
now i have a problem with the light connector, (has PIR)
out the box it was wired per the below red&white / grey / blue & white
I'm thinking I can't simply plug into the wall light mains connector block as they don't match up i.e. if i went red&white to the red live, ten the grey would be on neutral and the blue & white on earth.
please advise what i should do!?
your connections are in the right terminals, but ...
1. sleeve that bare earth wire green/yellow.
2. re-do the black so that there is no copper showing.
3. the red/white on that plug should go to the bottom terminal that has no incoming connection., so it's right in that respect.
4.the feed should be protected by a 3A or 5A double pole Fused Connection Unit ( fused spur).
hey everyone,
Hi Jake, those connections, and the entry into the light fitting leave a lot to be desired, you asked "what should I do" with respect, and with safety in mind I would advise the services of an Electrician, shouldn't take long, an not very costly to install the light correctly. You never know if a Forum member lives near you, they may be able to help, I would but you are to far away from me.
Reply to basic outside light wiring help in the UK Electrical Forum area at ElectriciansForums.net
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
