EddieB
344
46
101,203
Boys
I'm adding a couple of extra lights in a bathroom, do I need to install a rcd to cover them, being classed as a special location.
yes.....
Just a twist on it. if the cables are run in void above ceiling and lights are recessed LV and switch outside bathroom does it still need rcd ?
the elv lights are, and they are part of the circuit, even if they're separated by trannies.
Not saying i would not put rcd in, just more the circuit is outside. normally the switch is in there and there is a shaver point but just thinking into the wording really. gonna look in the lighting book now for lights you can glue the fronts on :p
EddieB
Bathroom additional lights
EddieB,
needasparks,
