Discuss Bathroom Heater - wired into Shaving socket?.... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
adammm
Hi Guys, I was wondering you could help me.
I want to fit a Bathroom Fan Heater into my bathroom and the only mains power will be the shaver socket ( which is conveniently just 50 cm below were I want the heater to be!) - I can hardwire directly to that? I do not use the shaver socket, so if it needs to be changed to another type of socket that's fine.
Many thanks!
Adammm,
Presuming this is not a joke, and just in case it is, I will start by being flippant and asking of your heater has a two pin 230v or 120v plug, in which case it may well will fit into your shaver socket.
Now, you did not ask if it will work, or be safe, which are actually more pertinent. No, of course, so don't try...
Before 'we' can advise, you would need to furnish details of the cable that supplies the socket, the protective devices pertaining to it, and other devices / accessories supplied by it.
Only then could I help, however there are others that may know better.
Anyhow, welcome to the forum.
Adam, Welcome to the forum.
sparks are like buses, there will be loads along shortly.
Good question, not as easy as you first thought, is it. The crazy guy above is correct though, there is a lot more info needed and only a slim chance it can be done as you say without alot of alterations to that supply.
Best bet is to get a sparks in to look at it.
Many thanks!
It's highly unlikely that a heater can be wired to a shaver socket,such a socket will normally be supplied from the local 6a lighting circuit. Installing a bathroom heater also comes under part P and has to be carried out in compliance with Bs 7671 and notified to building control,failure to comply is breaking the law. I would suggest you should use a qualified electrician for this.
Hi Crazy, no its not a joke:)
Thanks for your replies everyone, it does seem its not as straight forward as I thought! I thought that I could hardwire the heater into the shaver socket with some kind of in-line fuse box. I think I will get a sparky in!
For reference, the heater was - [h=1]Dimplex Fan Heater Wall Mounted IPX4 Rated with Runback Timer [/h]
Cheers guys!
For reference, the heater was - Dimplex Fan Heater Wall Mounted IPX4 Rated with Runback Timer
Cheers guys!
Aye, get sparky in! Without looking I'm still pretty sure that fan heater will be a 1/2kW heater (switch inside to choose between) - even on 1kW (which is only chosen on size of room) you will be most likely overloading the lighting circuit as wirepuller and others point out.
There will be a way, someone that does it all day everyday will be best bet.
Cheers
Spartykus
p.s. if you post roughly(!) where you are geographically, someone might offer to look ?
As Wirepuller says, a shaver socket is often fed from a 6A lighting circuit, so both the cabling and circuit protection would be unsuitable for the 2kW load you suggest.
A quick look at what gauge wire is present in the back box would be a good indication, as would seeing if the shaver socket is dead when the breaker feeding the room lighting is switched off.
But if there’s 2.5mm cable present, that would be good news, and worth investigating further.
BTW, are you sure you want one of these God-awful vintage-technology fan heaters? All they ever do (IMHO) is blow a lot of luke-warm air about, so unless left on for ages in advance add little to one’s comfort in the bathroom. I suggest you look at a quartz radiant heater instead (IP rated for bathrooms, and watch the zoning). INSTANT heat, no moving air and a pretty orange glow …
Reply to Bathroom Heater - wired into Shaving socket?.... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm about to do wiring for a small apartment in Azerbaijan. Mostly I will try to use UK standards - ring mains with ELCBs, everywhere earthed, T&E...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
DIY and new to the forum Hi there. I want to install a simple bathroom heater in my bathroom (this one: Wall fan Heater 7 DAY Timer PTC bathroom...
4K
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
