L
LlandrilloSpark
Guys
I've come accross A borrowed neutral in the upstairs/downstairs lighting circuits in a property where I'm fitting a nw dual rcd board.
It's the usual landing light job, feed from downstairs circuit, Neutral borrowed from upstairs circuit, I need to run a seperate neutral from the landing light rose to the loop in terminal in the downstairs hall light, the run starts in the attic then goes through a disused airing cupboard then under the floor, I'm going to run a single 1.5mm, even though it's technically hidden everywhere what do you all think is the best way to run or protect it, I was thinking mini trunking or oval conduit?
Cheers
Cheers
