Can I pick your collective brains please for a slightly odd situation I'm struggling to find a solution for.
Essentially a customer of ours has a swimming pool in an outbuilding a few yards from the house, but with a solid patio between the 2 that I'm not wanting to dig up if I can avoid it.
Basically their heating and electric bill is horrendous, mostly from heating the air in the swimming pool on a timer.
I've suggested we fit a remote switch in the house to allow them to switch the air heating on a few minutes before they actually want to have a swim, which I reckon will save them hundreds a year in only heating the pool room for a couple of hours a day when in use instead of the 10 hours a day it's currently timed for in case they want a swim.
problem is that I can't actually seem to find a suitable wireless remote switch relay system - I've seen a few options that need direct line of sight, but nothing that will penetrate a wall (it has to go through the wall into the plant room).
I did try to get them to let us just fit a switch in the pool house, but they weren't having that, so I'm back to trying to locate a suitable wireless remote switch relay system.
If anyone could post a link, or make of any suitable systems you're aware of it'd help a lot as I'm running out of ideas and google and city seem to be stumped.
I think the maximum load to be switched should just be a few hundred watts for the pump and boiler circuit - well under 500W anyway.
