Discuss Black box in old consumer unit - electrician stumped. in the UK Electrical Forum area at ElectriciansForums.net
Can any of you old pros out there help identify the middle black box made by Engel and Gibbs ltd. It buzzes sporadically, even when the main supply to the flat is off.
My electrician has never seen it before and can't figure out.
Thanks,
Alex
Possibly a contactor, possibly to do with the economy7 system as it appears there is electric heating
I reckon it's a Transistorised relay (Engel and Gibbs) could be used to switch ON and Off the floor warming system.
Agreed - probably underfloor heating contactor or mercury relay. Unusual design, would be interested to see inside (the cover comes off with two knurled nuts). If it turns out to be something interesting, I'd pay to have it posted here for the museum!
Thanks for the information guys. I've uploaded a photo under the hood.
I think it is a solenoid driven mercury tilt switch.
Be careful if it is, as you know Mercury is poisonous.
If you are going to dispose of them, they have to be treated as hazardous/poisonous waste.
Used for the same purpose to a contact set.
A control circuit operated the solenoid which in turn tilted the switch and the Mercury would make contact between two terminals in order to to carry a heavier load, e.g. Electric Underfloor Heating
The buzzing will likely be the solenoids.
can't see mercury. the moon and maybe venus from bedroom window on a clear night perhaps.
OK so it is a mercury relay as I thought. It's perfectly safe if you don't smash it, just like a mercury thermometer, because it's sealed. The humming is not a problem, many AC relays hum when energised, often it means there's some dust or grit inside that is just stopping the armature fractionally short.
One of the load terminals has overheated - is the underfloor heating still going to be in use? If so, this should be repaired or replaced. If it does get replaced, I'll cover your costs to send it for the museum and then you don't have to think about disposal - you can't put it in normal refuse because it will get crushed and the mercury will escape.
Reply to Black box in old consumer unit - electrician stumped. in the UK Electrical Forum area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Hi, My electrics keep tripping.. this black box in the picture seems to be the culprit. Slight touch of it and it trips. The electrician suggested...
5K
Hi All, I am in the middle of purchasing a small 1 bed flat in England, and have been sent a Domestic Electrical Installation Certificate by the...
