- Reaction score
- 2,118
Have you another mft to try or another set of leadsYes leads all nulled before testing
Discuss Black cable off supplier's incoming cable? in the UK Electrical Forum area at ElectriciansForums.net
Good shout. I’ll grab one from the other electrician I work with and test on MondayHave you another mft to try or another set of leads
You have a field and a barn? You kept that quiet.I will have to tell the amalgamating tape around the junction box to the alarm cable in my field to the barn that it should not have lasted twenty years, naught tape.
This is the stuff that I've been using, I bought a dose of them a few years ago, I see that it was discontinued in 2019.Must have been cheap stuff.
I wonder if you are using fluke, as there was something about double nulling causing problems.Good shout. I’ll grab one from the other electrician I work with and test on Monday
Interesting didn’t know about the double nulling issue. Yes using a fluke 1653. I’ll keep you updated next week once re-test doneI wonder if you are using fluke, as there was something about double nulling causing problems.
Let us know how you got on.
been searching for S/A tape in Green/Yellow. can't find any anywhere.This is the stuff that I've been using, I bought a dose of them a few years ago, I see that it was discontinued in 2019.
Hi apologies for the delay, I have only got around to re-doing the test yesterday as caught up between jobs. I used my colleague’s tester and got 0.10 then I re-tried my Fluke considering the possible double nulling when I did the test previously and got 0.11 so looks like I might have double nulled when I did the test before. Thanks for the heads up on thatDo you have any news ?
I asked him at the time and he said it was electrical tape. Assuming he should have used self amalgamating tape?
Reply to Black cable off supplier's incoming cable? in the UK Electrical Forum area at ElectriciansForums.net
