Discuss Cable size in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Looking for advice,
Doing a new build in a rural location and I’m having to run a mains electricity 500m to the nearest meter.
Had a couple of quotes so far but there vary massively in price.
The first quote the electrician was going to use 16mm cable which even I thought would be too small to account for voltage drop over 500m
Second quote said I needed 300mm cable so obviously there is a huge difference in price.
I know that I’m able to get 3 phase down there and have been told this may be my cheapest options but can anyone offer some advice as I don’t really know who to believe right now.
16mm is way out of scale. What is your loading and what volt drop are you allowing for.
Holy shitballs
Volt drop should not exceed 3% for lighting and that is from source of supply to the furthest point of a lighting circuit so the submain if often rule of thumbed at 1%. Given this and the length and anticipated loading 300mm is not large enough. What you propose is unrealistic in real terms.
500 meters is a hell of a distance.... As above, speak to the DNO.
I calculate roughly you would require 3× 185mm, 4 core cables for a 1% volt drop. Cable cost between £80-85k plus a couple of grand for switch gear.
You need to do some proper loading calculations..
Maximum demand, diversity, etc.
You might be able to use 35mm or 50mm cable.
What equipment will you be powering up?
Other options available such as step up transformers but I feel you are over spec’ the load
Yes one guy I got a quote from has said that I would be able to possible use a 35mm - 50mm 3 phase set up.
It’s just for a 2 bed bungalow, will have an electric shower and cooker
Reply to Cable size in the UK Electrical Forum area at ElectriciansForums.net
Does anyone know the size (diameter) of a reel of 2.5 twin and cpc cable ? i want to put a pole in the van but I don’t have any reels with me here.
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
I am an enthusiastic retired engineer rebuilding a barn in France from scratch and am having problems sizing my incoming electrical cables. I have...
Hi All, Wondering if I can get some advice. Basically I’m having exposed joist ceilings in my house and I’m in the process of slowly changing all...
