Discuss Cables and trunking. in the UK Electrical Forum area at ElectriciansForums.net
Hello. Could anyone tell me what would be the best size plastic trunking for 2.5mm square cable internally? my guess is probably 16mm square but not sure.
Thanks for your help.
16x16 is big enough for 2.5 t&e, if it’s a straight run.... no bends.
25 x 16 gives a little more room.... 2 cables, again, if it’s a straight run.
Correct fixings required to prevent premature collapse in case of fire.
Hello. When using 1.5mm flex cable what would be a suitable size of trunking for this?
In the past, I would try use 16x16 for one or even two 2.5mm2, and 2 or even 3 smaller cables. But often there would be tight spots like bends or trying to enter down the side of a pattress. So having used up what stock I had, I now generally use 25x16, saves time trying to get cables to fit properly. Unless there are more cables and something bigger is called for.
Reply to Cables and trunking. in the UK Electrical Forum area at ElectriciansForums.net
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online. I've taken over a job that's used 16mm twin and earth...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
Hi Everyone, Sorry if this is a silly question. I am supporting my mum with some small home renovations, in preparation for a care home. I am...
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
