Discuss can I change a dimension of a fuse in the UK Electrical Forum area at ElectriciansForums.net
Marktee
I could find the fuse on the top right of the image which measures less than 1.7 inches in length from end to end and has 150 amps. (grey color). The fuse is inside a SAM module in a Mercedes. None of the auto part stores have it and the dealer do not carry more than 100 amps. They want to sell me the whole module for one bad fuse and which cost close to a 1000 dollars.
My question is: would a different dimension fuse with a150 amps work if I change only the size on both ends of the fuse?
Yes a longer fuse rated at 150amp would work.
This fuse seems to be available online tho', not sure where in the World you are, DFW is that Dallas Fort Worth?
They'll also be commonly used on boats.
150amp Midi fuse.
I was looking on Amazon and eBay for probably fast delivery but couldn’t find. I never thought of eEuroparts Thank you.
Yes It is Dallas Fort Worth
Reply to can I change a dimension of a fuse in the UK Electrical Forum area at ElectriciansForums.net
This fuse link belongs to a Mercedes Benz. I have soldered the filament of the 40 amps fuse and I do not know if it works. The dealer does not...
  • Locked
5K
I hear many views of people who believe that DPF's and CDPF's fitted to their vehicles are a problem and many people resort to removing them, or...
8K
Hi guys, Im new here and desperate for some help, I have posted this on multiple mini forums and the car has also been to multiple garages and an...
32K
Hi all I have some unused new/boxed Duraplug FC4134WHI which I bought for a recording studio/live rooms project which ended up being a far...
