Discuss Can I join 6mm and 2.5mm cable in radial circuit in the DIY Electrical Advice area at ElectriciansForums.net
Pmozza
Hi all, I’m new to this forum so please bear with me. I live in a bungalow and would like to repurpose an unused shower cable to supply one new double socket. The radial shower circuit cable is 6mm and protected by a 40A mcb. My plan is to connect the 6mm cable to a length of 2.5mm cable which will run to the new socket in a utility room. My question is can I simply join the cables in a 30A jct box in the loft and replace the 40A breaker with a lower rated 20A version at the consumer unit. The socket will feed a washing machine and tumble drier - both machines are modern and efficient. Would this approach be safe and appropriate? Thanks in advance
Reply to Can I join 6mm and 2.5mm cable in radial circuit in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
I've been asked to change few double sockets, but not keen on touching after seeing 6mm cable, so did a bit of checking as can see the kitchen...
4K
Hello Electrical world. Looking for thoughts and opinions. Currently planning out my kitchen re-wire for new kitchen. I was originally...
HI All, I am building a new house (self build) and have my part P so am running the cabling. My reading of the regs says that any appliance of...
4K
  • Locked
5K
