Discuss Can somebody help? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
Pete/2472
:eek: Hi
wonder if someone can help
Ive got a ring main serving four socket outlets in an hospital job that will not test, new installation that finished last friday but just cannot get the rcd tests to comply! (Be gratefull for any ideas)sinking ship
Approximate run 35mtrs 2.5 singles no damage to cables
R1+R2 fine Zs 0.40 rcd 1x 310ms 5x 50ms 30ma
Have tested ring for end to end
Have traced all cables back to board
Replaced the new rcbo with another£
all other circuits tested and job complete
thanks if you can help
Pete
Hi Pete, the previous comment about using another meter could do the trick. I had a similar problem earlier this year actually during my 2391 practical exam. Using a Fluke(belonging to the college) the readings were way over. I used my own megger on it and the readings were exactly what I expected them to be. I couldn't get round it any other way as the examiner was hovering over my shoulder and agreed that some meters just don't like some installations.
Reply to Can somebody help? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Evening all, Been to a job on Fri where the customer had a condition report completed. Two of the remedial identified was that there were too...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
