speedtronic
For a single phase capacitor start motor, what will happen if we use a capacitor whose rating (capacitance uF) is lower or higher than the actual rating mentioned for that particular circuit?
Discuss capacitor start motor in the Electrical Forum Canada area at ElectriciansForums.net
Hi.
A rating below the required capacitance and the motor will not run up to the desired speed before the capacitor is de-enrgised so therefore will not reach full speed and the centrifugal switch may not operate meaning that the start capacitor will not de-energise so will stay in circuit and break.
A rating above and you risk too much input charge from the capacitor which may then damage the motor itself by causing it to run too quickly before the capacitor drops out.
The centrifugal switch may protect from overspeed but I would not install a capacitor that wasn't fit for purpose. Use the correct one.
Nice little link Andy.
I've always thought of it as being the same kind of principal as a star-delta on a 3P motor i.e starting on one and swapping to the other when up to speed. Not exactly the same thing I know but in theory similar.
Reply to capacitor start motor in the Electrical Forum Canada area at ElectriciansForums.net
