Discuss Circuit for a gas solinoid valve in the UK Electrical Forum area at ElectriciansForums.net
How all,
Doing a commercial kitchen with fans above the gas cookers , there is a solinoid gas value that opens the gas when the fans kick in, does this have to be wired on a dedicated circuit , there is a socket right next to it . Board is quite far away .
Cheers
Grand
How all,
Cheers
Grand
Wouldn't how this is wired all depend on the results of a risk assessment?
Can’t supply that off a local socket. Any safety systems including solenoids for gas shut off valves need to be controlled by specific control measure for that system. Also you would probably need to incorporate Fail safes etc.
I think the OP is asking whether a gas interlock panel and system can be supplied from (e.g.) a fused spur from a socket-outlet circuit, or whether a dedicated radial needs to be run from the DB. I would defer to the specifier of the system as they will be responsible for demonstrating compliance with BS6173 etc. FWIW the load is trivial, a fraction of an amp, other than for the fans themselves.
I have seen them wired both ways, personally I would use a dedicated circuit. The supply isn't a safety system as such, if it were it would have some kind of battery back up and be wired using fire retardant cable. Loss of the mains supply would merely default the gas solenoid to close, in a safe position.
Is this being controlled by an interlock system to prevent a gas supply if the extraction is off or if the extraction system fails.
Reply to Circuit for a gas solinoid valve in the UK Electrical Forum area at ElectriciansForums.net
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
