Discuss conduit singles to T&E in the Australia area at ElectriciansForums.net
L
lionelmcc
Hi Folks
I have 1.5 conduit singles running vertical from a bend in 20mm conduit to an angle box.
the plan was to terminate from the angle box onto 1mm T&E.
How can I support the weight of the singles without putting strain on the terminals? It's about two an a half meters from the bend to the angle box.
L
How are you joining the two cables?
I think insulated through crimps would be best, but thinking about it, im not sure you really need to support anything.
I was planning to use connector block, I was wondering if could clip inside the box or perhaps draw the single through a stepped grommet and tie wrap them.
I know there is not much weight is the singles , but for future reference , how could such an arrangement be supported supposing there was more weight?
any other ideas?
I would be more concerned about down sizing to a 1.00mm t&e from a 1.5 circuit, what breakers behind it, as if its a 10amp , 1.00 t&e is no good.
Thanks Des
No problem there ; it's a switch wire to a flourescent on a 6a MCB toal load = 0.18a; around 0.3 with start induction.
L
Reply to conduit singles to T&E in the Australia area at ElectriciansForums.net
Hi, My first post so hopefully I am correct in posting it here. My question is, I am thinking of an IP rated outdoor socket for the back garden...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
Got an EICR testing to do on a site soon. Some was done 2018, some 2014... but their office cant find the reports... So got to start from scratch...
7K
