- Mar 25, 2021
- 5
- 0
- 31
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi. Renovating bathroom. I need supplies to power
(1) fan
(2) electric towel rail
(3) underfloor heating and
(4) Mira digital shower/bath filler.
I have a spare path on the main consumer unit (was the electric shower) and was considering putting a second CU in the loft to drive these. Comments please?
If possible
(1) fan
If possible
- what MCB should I have at the main CU.
- What MCB should I have for each of the above. Note - the fan won't be on the lighting circuit as the Mrs wants dimmable lights!
- What size cable from the main CU
