Discuss Convert 6mm cooker connection point to 13a fuse spur for oven in the UK Electrical Forum area at ElectriciansForums.net
Hi
So converting a 6mm cooker connection point into a 13a unswitched fuse spur with the load being a 2.5mm pre wired cable from a oven .
is this suitable?
thanks
sid
Hi
is this suitable?
thanks
sid
Be better having switching for isolation.
What's the rating of the oven? Not a fan of running things through a 13A cartridge fuse if there's likely to be a load of approaching the full 13A for any length of time.
Would be better to reduce the 32A protection device in the CU to 20A or 16A, and fit a DP switch* for local isolation.
*This can probably be the existing one
Reply to Convert 6mm cooker connection point to 13a fuse spur for oven in the UK Electrical Forum area at ElectriciansForums.net
Is this ok? 32amp breaker with a 6mm wire leading to fused cooker switch. This then leads with 6mm cable to hardwire point. Can i hardwire 2 x...
OLDBOY
O
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
