- Feb 10, 2012
- 2,264
- 2,984
- 4,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- If other, please explain
- Running own small electrical company.
I have a customer who has 2 supplies, due to the property (4-bedroom house) originally having been 2 separate houses (1-bed, 3-bed), now joined with internal doorway downstairs. Both properties have old Wylex fuse boards (5 ways in use in each), intent is to replace both of these with one modern consumer unit at one location from one supply. Once that is complete, the customer wants to have the unused supply disconnected.
One supply (the 3-bed) is outside the property at the front, accessible via an external meter cupboard. The Wylex DB is inside the rather cramped meter cupboard. It is not so convenient to retain.
The other supply (the 1-bed) is inside the house, mid-way on the wall adjoining the other house, and a lot more convenient to use both because there is lots of space for a new CU, and easier to get to from the other house.
Both supplies are TN-S, with 60A fuses. There are no electric showers, a gas hob, but an electric oven. Probably 60A will be sufficient for the combined property.
If the customer asks the DNO (SSE) to disconnect one supply, will they care that they are disconnecting the one with outside access, and leaving the one with internal meter access only? Do they have any say in these things, or can the customer just specify which one to keep?
