Discuss Cost for 5 downlights guys in the UK Electrical Forum area at ElectriciansForums.net
sys3
Hi, just popped over from the Plumbers Forum and would appreciate some advice. I'm preparing a bathroom quotation that includes wiring up 5 12v chrome downlights with supply taken from existing ceiling rose fitting.
I'm drilling and fitting the downlights into PVC ceiling cladding and supplying the transformers and bulbs, so the spark needs to wire and connect everything up.
How much approximately for wiring 5 downlights so I can get my quote posted. My usual spark is in Ibiza and this is getting urgent!
i would never quote without seeing when it's unknown what's required. Oldtimer's in Edinburgh, maybe he can help out.
Seems a bit cheap, would have thought more £30 a light, supply, fit and test. Thats assuming all other circuits in the bathroom have rcd protection and/or earthing is correct. Sparks do like to buy food now and again.
80 notes seems very cheap who knows what condition original cable is in, how it is wired, if it needs replacing cosmetic damage occured, as many houses don't have rcd's is one needed.
too many reasons to do the job and get nothing back.
get a quote off an electrician that can see the job himself is my advice.
would a plummer give a quote without knowing size of property etc?
I have a quote done today for 4 D/L.
New C/U was done last week.
Quoting for LED IP rated downlights, obviously you are paying for these so allow accordingly.....
You need to get a spark to look at it, if the circuit has no RCD, then one is fitted and it keeps tripping/doesnt pass testing, circuit needs rewiring then you are talking a few more pennies then £80 quid, that would be coming out of your pocket for not qouting correctly too remember!!!
If all is ok sticking 5 lights up (you supplied) it may be enough.
Have installed ELV spots into a bathroom before, only for the ceiling to be redone in that PVC stuff at a later date. I have been back to do other stuff since and its started to melt already, in roughly 12 months.
Would never even contemplate fitting anything other than LEDs in that sort of cladding. Scrop the ELV idea and go for mains LEDs.
Also to the OP, is there main bonding? RCD to lighting? Electric shower installed?
Reply to Cost for 5 downlights guys in the UK Electrical Forum area at ElectriciansForums.net
I have two downlights in my hall with MR16 bulbs. These are now leds, obviously in the past they were halogens. The fittings are really old and...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi guys, Bare with me, hope this makes sense.... I have 3 separate mains (240v) lighting circuits in my kitchen all going back to a 3 way 1G wall...
No lighting has been changed in the house for at least 12 months. Last night a small pop similar to that of a small firework in the distance came...
