Discuss creda storage heater in the The Welcome Forum area at ElectriciansForums.net
the Money you spend on a tester, would be better spent on an electrician that can help you. Doesnot take more than half an hour to fault find a storage heater.
What’s your location someone on here may help?
Reply to creda storage heater in the The Welcome Forum area at ElectriciansForums.net
Morning I just wanted post this information for anyone that may come across these Storage Heaters as I have struggled to find any relevant...
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
Hi all, I have an Economy 7 storage heater Dimplex CXL24N - 3.4kW Storage Heater + Convector ( there not available anymore) that dos'nt work and...
I recently got my flat rewired. It had old storage heaters and we plan on putting modern storage heaters in. The way the electrician did the...
Hi, My electrician removed an old Creda storage heater connected to only 1 off peak supply and installed the SSHE070 but as the power is off peak...
