Discuss Cross bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sparks1234
Guys,
What are the regulations these days on cross bonding.
We have a room that has a sink in it with obviously hot and cold water supplied.
The local sockets are RCD protected but the lights are not but then they are out of reach.
I'm not interested in whether it only costs a couple of quid to put a couple of earth clamps on, all I want to know is if it is necessary or not
Cheers guys
Guys,
Cheers guys
Are the pipes actually extraneous?
Guys,
Cheers guys
Test it and find out?
https://www.youtube.com/watch?v=v38PfIVy2rI
What does your regulations book say on the subject. You'll have better luck looking for supplementary bonding rather than cross bonding, that term is long gone!
Firstly, is the room classed as a special location i.e does it contain a bath or shower? if your answer is no then you will not need to provide supplementary bonding unless the pipework has been tested and proved to be extraneous in its own right in which case youd need to carry out a main protective bonding exercise. The only other time you may need to carry out sup bonding to the pipework would be if your socket / light loop values are to high to afford the required disconnection times. Most probable answer to the above is no therefore save your clamps and time.[emoji106][emoji106]
Nope, as I said, its just an office that has a sink in it
Reply to Cross bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
Apologies if this is in the wrong section - appreciate it's more of an educational question. That said I have 2391 - but the classroom environment...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
