Discuss CTI RCBOs ...................... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
even before the 18th edition suggested we should fit the same manufacturers products, I have always been inclined to do it anyway ...
So now I need to locate RCBOs to go in a fairly new CTI metal cu ..
Anyone know who sells this kit?
It looks almost identical to Lewdens, control gear
I think replacing MCB's or RCD's in a CU like-for-like with the same brand could arguably maintain the fairytale designated KA rating due to 'type testing'.
Replacing a device such as an MCB with and RCD or RCBO or adding RCBO's or even AFI's to a CU that never had them could arguably be a deviation from it's original design and negate the type tested rating.
Well, come the 1st January 2019 we in the UK have little option but to go for the same make ....
The vested interests on JPEL / 64 get to make more money
... Replacing a device such as an MCB with and RCD or RCBO or adding RCBO's or even AFI's to a CU that never had them could arguably be a deviation from it's original design and negate the type tested rating.
Agree - even with a new (but different) device from the same manufacturer I think it means we should really have a statement that specific configuration is supported by them. Dear oh dear.
Reply to CTI RCBOs ...................... in the UK Electrical Forum area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hello all.. I'm quoting for some work and would like change the type AC RCBO to a type A. Consumer unit is a castlec which I have not come...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
  • Locked
5K
