Discuss Cylinder stat and pump wiring in the Central Heating Systems area at ElectriciansForums.net
N
Norn Iron
Hi Guys
Need some help on a Shed/Workshop heating system, haven't really done much work on heating systems. Basically there is a wood burning fire, a cylinder and a pump. The way they want this wired is that the cylinder stat does it normal job of when it reaches its temp it brings the pump on, but they also want the pump to have a switch so that they can turn it on when they want too.
If anybody can help with this it would be very much appreciated or even if somebody had a wiring diagram they could forward on would help me out big time.
That could be done by bringing the supply through a 3 position switch. This would give you the option of having the pump either permantly on permantly off or automatically on via the cylinder stat.
Thanks Sintra so would i just take my supply into this and bring the cylinder stat and pump flexs to this switch aswell? Sorry if this sounds like a silly question but like I said have never wired this sort of system before!
Is it a back boiler heating the cylinder?
If so, how do you disperse the heat when the pump is not running? (stop it boiling)
Boydy
Boydy
Hi Boydy yeah its a back boiler, My understanding is that the pump will run when the cylinder stat reaches the cut out temp and pump the heat round, But they also want it so that they can switch the pump on whenever they want to I dont know why but am also unsure how to wire this correctly!
Am I right in thinking that this is gonna need wired like an ordinary heating system as it is fed by a log burner back boiler and there are 6 radiators on the system?
Reply to Cylinder stat and pump wiring in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Friend asked me to wire in a hive on a conventional 1 zone heating system. So I fitted it tested the HIVE and all was working. I then said to him...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
