Discuss Danfoss FC51 lack of power options in configuration in the Commercial Electrical Advice area at ElectriciansForums.net
Hi all.
I have a Danfoss FC51 vfd. When I go to the menu 1-20, only appears the options from 8 to 11, which corresponds to a 1.1kW to 3kW.
I have tested directly in the local console and also with the MCT10 software, there are only the options from 8 to 11 available
I have a motor of 700W, but I can´t configure that power.
I would appreciate some help about this.
Hi all.
Attached a screenshot
Hi all.
Looks like you need to buy a smaller inverter
Reply to Danfoss FC51 lack of power options in configuration in the Commercial Electrical Advice area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Hi All, long time no see. I was having a problem with LED controller failures, so instead of sitting there for hours watching a scope and a...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
5K
