Discuss daytime running lights in the Auto Electrician Forum area at ElectriciansForums.net
F
Fenton
Hi I need some advice.
A friend of mine has fitted daytime running lights to his classic car .
it has been fitted with an alternator and he is using the charging wire from it to operate the relay for the lights .
this means the lights only work when here is a charge and no switch is required .
Could you help and tell me which wire from the alternator is the charge wire?
Many thanks
John
Reply to daytime running lights in the Auto Electrician Forum area at ElectriciansForums.net
Hello all, I have a tail light for a '12 Ducati Panigale 1199 S, that I can't get working properly. The brake light / daytime running lights...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi, I have run some outside lighting for a customer in Hi-tuff cable. He now wants 2 additional lights run across scaffolding which has been put...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
