Discuss DB upgrade advice appreciated in the UK Electrical Forum area at ElectriciansForums.net
You say you're a relatively new domestic installer so the first question I would ask myself is... are you skilled and confident enough to tackle this particular job? You need to balance the loads over the 3 phases but at the same time be aware of the location of every circuit because you could end up with 2 phases in 2 socket oulets next to each other for example. You last photo looks like a sub-distribution board which would supply the consumer units and maybe other boards. Impossible to say though by just looking at photos. The cabling looks a mess and to be honest looks like a complete strip out would be required to get it right. It would need designing and a few days spent on it before you start anything.
Confident enough if I got it back to a single phase installation... skilled enough? Probably not that’s why I am definitely going back with a more experienced sparky and quite happy to hand the job over and shadow them. It’s a bit different to anything I’ve seen in the classroom!!!
There’s been enough points raised on here to confirm my suspicions that I could easily end up being in over my head. I know my limitations, I wish others did then maybe we wouldn’t see installations as messy as this.
I have greatly appreciated everyone sharing their thoughts and opinions, I had a lot of nagging doubts about this anyway. I’m happy to take a step back and keep learning.
Its possible that a lot of the equipment may be/become redundant following a previous upgrade to a wet heating system and upgrade of distribution board/consumer unit.?
Once the redundant services are removed it may become much more straightforward with a single phase supply being adequate.
Needs a more thorough inspection/test.
If you are new to the trade , the other import thing is how you cost such a job.
DO you price by the hour and give them a rough estimate including all materials. OR do you give them a fixed price.
A job like this for someone very experienced is probably a day or so work , but if you are brand new out the box you could end up spending days and days on it...
Reply to DB upgrade advice appreciated in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
