Discuss DNO or Not DNO, that is the question.... in the UK Electrical Forum area at ElectriciansForums.net
Looks like an old woopy cushion taped over it ?
I was wondering what it reminded me of!
Only seen a picture so far - will investigate on Friday but I assume it's something they carry on the van as usual and not just whatever he had in his pocket at the time.....
Reply to DNO or Not DNO, that is the question.... in the UK Electrical Forum area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
So this is 1st floor maisonnette with concrete floor, 16mm2 single insulated tails coming from dual cut out on ground floor, through steel...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
I've come across this incomer, looks like 10mm conductors. The dno has upgraded the meter and used a 100A fuse. So my question is, does this...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
