Test everything, make a note of every fault or issue.
then give them 2 quotes, if you are realistic with your prices for the remedial work, you'll find the rewire comes cheaper, with the benefit of extra sockets and switches.
as said before your certificates will back up any quotes
Thanks everyone - I'm taking my Kewtech for a run out on the house next Monday. one strange,curious thing I found is that the walls are cast concrete, then external walls there is galvanised steel floor to ceiling, then wood cladding (tongue and groove). internal walls are plastered. my spidey senses are worried about the largely inaccessible steel walls though in terms of earthing/bonding ......
good luck with that one. relatives always expect it for nowt or a few quid beer money.
not only relatives. did a day's work for a retired, well off doctor a few weeks ago. it was an easy job and i know his son, so charged him £30, most of which was materials. he looked at me as if I'd shot his lancaster out of the sky.
I got that sorted from the start! I give him a good price of £30 p/hour and just do whatever, i can't work for free :D he doesn't know thats what i normally charge anyway, i should be on danger money in that place anyway!
Ah the dreaded board upgrade, that's why I don't do domestic systems, but have to agree with many of the comments though..
1: Quote to Test and Inspect the installation prior to undertaking any work, explain that if you simply upgrade the board this does not automatically make the installation safe, only safer, but it could introduce problems that are them expensive to solve, such as faults causing nuisance tripping than BS3036 or other types of fuses would ignore.
2: Quote for the rewire and include the costs of the CU upgrade (Explain this included the costs of a post installation test and certification anyway). I would sweeten the pot with a couple of smoke detectors and a heat detector (kitchen) thrown in free (if gas in kitchen consider a combined heat/CO2 detector)
3: Quote to only do the board, but state that you would not be prepared to undertake the works without testing it first because you are legally responsible and you could not in all conscience undertake any work you consider to be substandard.
Remember to explain the merits of rewiring the house, this does make the home safer, it may decrease their home insurance policy and it also means it will not be necessary for about 20-25 years so actually will help the sale of the house should they choose to sell at any point.
only if the existing installation fails
stop it...no hard sell ....it isn`t windows n doors you know....
Get off your soap box, there is no hard sell in explaining reality should the installation fail any tests, but if the installation is more than 25 years old it should be rewired anyway and the test would be largely irrelevant.
Why should it be rewired if over 25 years? If all test confirm wiring is ok there's no point
Because PVC cable loses it's plasticiser over time and can become brittle, it loses some of it's insulating abilities and if you bother to read the regs it actually states this as a recommendation. Not a hard and fast rule, but it is a sensible one.
So even if it tests out ok after 25 years you would still advise a rewire? do you ride a horse and wear a mask to work?
I must admit i've not seen that in the regs, enlighten me?
When I get home I will find where the comments are in the current regs books.
However in the meantime
BASEC said:
There are no requirements for life expectancy set out in cable standards and specifications. However, reputable cable manufacturers will state a probable life expectancy for their products, which for building wiring is usually 20 years when run at the rated temperature. However, under ideal circumstances, with lower loadings and minimal heating, it has been observed that cables can remain safely in operation for up to 50 years.
Cables degrade over time primarily due to changes in the polymers used for insulation and sheathing. The main cause of polymer degradation is too much heat, from either excessive current loading or from the environment - such as heated spaces. Cables loaded or heated for 24 hours a day will degrade faster than those used only during working hours – for example, commercial lighting circuits are often operated continuously.
LINK
I think we all know what can happen to cables, but like monkeyelectric has said, testing and inspection will confirm whether or not they are suitable for continued service. If you are concerned about old cables that test out fine, then more regular periodic testing of the installation would be advisable, not a rip out and start again job when it isn't needed.
FFS, did I post in Chinese Guys, I did not say they should have it rewired, I said it should be a recommendation and at no point did I say it should not be tested first...I seem to recall the first item on my list was a quote for Testing!!
Don't take it personally, it is like this all the time round here. :)
The Basec thing states:
I can't imagine many domestic installations run at 70 degrees as a matter of course. If I found my cabling was around that temperature normally I wouldn't be happy!
