Discuss Do this particual model of LED strips produce ANY UV at all? in the Lighting Forum area at ElectriciansForums.net
Hello everybody,
I have question about LED strips.
I have movie prop that is very,VERY fragile and it's very sensitive to UV.
I have it displayed in my cabinet and I bought LED strips for illumination.
Problem is that I'm not sure if model that I bought emits UV even in smallest quantity.
I know some people are saying that LED don't produce UV at all,but that's not completely true.
Some models do and some don't.
I read that phosphorus have role in producing UV when it comes to LED lights.
I tried to contact company that made LED strip I get but they didn't replied to me back.
I was hoping that you may know if this particular model produce any UV?
Model name is Optonica LED Strip 12V 2835 60 LEDs SKU:4703
I manage to find them in catalog and I made a screen shot so you don't have to bother searching for it.
I'll post it so you can see specifications.
TL;DR
Does my model of LED strips produce ANY UV at all?
Not sure about UV from LED strip, but what about the UV from any other light source such as sunlight?
you can get UV blocking windows, so how about a UV blocking glass box around your prop, and the LED outside the box, but all still within the display cabinet?
You could purchase or hire a light meter that measures UV to check both the output of any lights you install plus the general ambient lighting in the final setting.
Museums have very specific requirement in terms of lux levels and UV exposure for lots of their objects so these kinds of meters are used to set levels and check the UV output of lighting.
An (expensive) example I've seen used:
Cheaper ones are available but it might be worth hiring a quality unit.
Reply to Do this particual model of LED strips produce ANY UV at all? in the Lighting Forum area at ElectriciansForums.net
Hi, I have bought a LED Lighting Strip (20 metres) to sit inside some Screwfix coving for my bedroom. Although it will be controlled by the...
Hello everybody, I just joined this forum to ask for your advice. I have one very fragile object that I want to light up with some LED stripes...
I've purchased Lepro 15m LED strip lights - product code PR410047-RGB-UK, and have fitted them at the top of the walls in my daughter's bedroom...
Hi there. I'm building a house and need some help with the LED lighting design. Lots of experience wiring things, some experience using LEDs (did...
A client asked me to fit some LED strip lights, 1m long, easy enough, they bought them, probably on Amazon, 3 pin plug with 6 inches of wire and...
6K
