- Reaction score
- 25,532
Depends what the block connector is rated at.I come across that fairly frequently doing EICRs, even where there are spare ways. Do people really think that it's ok
Ours takes so long to do anything it never gets to that stage. I'd wired a load of klik sockets, dressed the wires back and pushed them into the conduit boxes. Gave apprentice bag of brass screws and screwdriver, but he was unable to screw the sockets back.One of the clever ones for a change
Did you show him which way to turn the screws.Ours takes so long to do anything it never gets to that stage. I'd wired a load of klik sockets, dressed the wires back and pushed them into the conduit boxes. Gave apprentice bag of brass screws and screwdriver, but he was unable to screw the sockets back.
Oh well, at least they parked it on a screw rather than snipping it off!Too many to post but here's another.
That is the one, it was quite neatly done (poor terminations) and they almost got the lid of the plug closed as well, unfortunately did not quite manage to safely earth the armour!!New way to terminate swa - straight into a 13A plug - is that what I'm seeing?
Just a bit of surface dirt, it will brush off.It's ok, it'll work - it's an MK!
Looks like it's been used for late night target practiceJust a bit of surface dirt, it will brush off.
WTF WHY
How long did that take you Leesparkykent?
Safe Zones outside?Hrrrmmm, done that to my outside light for a couple of courses, in the safe zone though
Safe Zones outside?
OHPPHH That looks nastyBeen doing some DIY at home on my week off, found 2 of these after removing a section of ceiling. Not entirely the boarders fault, the thick electrician has drilled all the holes at the bottom of all the joists...
that's quite a novel way of cable restaint.Been doing some DIY at home on my week off, found 2 of these after removing a section of ceiling. Not entirely the boarders fault, the thick electrician has drilled all the holes at the bottom of all the joists...
Oh, that's how you spell OHPPHH - I always wondered! It sounds about right!OHPPHH That looks nasty
Why not Pete outside light creates one outside? Building inspectors just looked at one I did that's going to be rendered over, never said anything.Safe Zones outside?
And the even thicker boarder has shoved the screw straight through it, would still have hit the cable even if it had been higher. Some of these other "trades" just go hell for leather like maniacs.Been doing some DIY at home on my week off, found 2 of these after removing a section of ceiling. Not entirely the boarders fault, the thick electrician has drilled all the holes at the bottom of all the joists...
And the even thicker boarder has shoved the screw straight through it, would still have hit the cable even if it had been higher. ALL of these other "trades" just go hell for leather like maniacs.
Oohhh niceThis is what happenes when our company decides to put 16A plugs on a 32A TIG plant.
It's makes unplugging ones welding plant quite difficult!
Looks like another case of "get it working no matter what"They did say that burnt toast was bad for us, so this is probably not good either ...
