V
varilite
Is having all the lighting circuits on 1 RCD in a dual board considered a C3 on an EICR? To me it defeats the object of the exercise.
Discuss Duel rcd consumer unit in the UK Electrical Forum area at ElectriciansForums.net
what do you think about the fact for a small cost to the customer you could swap one circuit over to the other RCD and not make mountains out of mole hills?Is having all the lighting circuits on 1 RCD in a dual board considered a C3 on an EICR? To me it defeats the object of the exercise.
The occupier of the house is moving so he dosent care, if new owners want it done if and when they complete the house sale I shall oblige.what do you think about the fact for a small cost to the customer you could swap one circuit over to the other RCD and not make mountains out of mole hills?
ah well then so what ha ha , I'm sure it's fine.unless theres a shared neutral.
Trust you to throw your proverbial spanner into the worksunless there's a shared neutral.
depends Mike....what do you think about the fact for a small cost to the customer you could swap one circuit over to the other RCD and not make mountains out of mole hills?
thats why both lighting circuits go on the same OPD Tel in them situations.....if there was a shared neutral, then i'd give it a code C3. mybe if i was in a bad mood, like if the offy had run out of beer, then a C2. after all, if a Electrical Trainee isolates the upstairs lights to change the landing lights, it's a potential danger. on 2nd thoughts, bugger it. 1 down 55,999 to go.
Reply to Duel rcd consumer unit in the UK Electrical Forum area at ElectriciansForums.net
