Discuss EFL on TN-S with RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
devon1
I'm doing 30mA & 100mA RCD resting on a TN-S system
TN-S earth fault loop impedance max is .8 ohms
TT earth fault loop impedance max is 200 ohms
Regs state approx 1500 ohms for RCD on TT system
What should the maximum Zs be on a TN-S system when testing an RCD?
On a 230V supply Max Zs can be worked out like this:
Max Zs = 50V ÷ IΔn
So for a 30mA RCD the max Zs is 1666.66Ω (50 ÷ 0.03 = 1666.66) and for a 100mA RCD it is 500Ω (50 ÷ 0.1 = 500)
The maximum a 30mA can protect at is 1666 as Jud has said however, it should still be below 200 Ohms on a TT and irrespective of RCD protection or not the max ZS on an a TN-S should still be around 0.8
That would be Ze, not Zs.
A Ze or Ra of more than 200Ω on a TT is considered unstable as Caddy says.
The maximum Zs of circuits on a TN system should be taken from Tables 41.2 to 41.4 on pages 48 & 49 of BS7671.
devon1, I've just noticed your qualifications in your signature.
With those qualifications you really should know all this ;)
yeah i just need to explain it to the electrical engineer on site! The engineer is telling us that the Zs max is 1500 ohms on the TN-S
Reply to EFL on TN-S with RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Keeping this brief.....................New dwelling.....TT system with 100mA S type rcd protected supply to local board with 30mA RCD. Freelance...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Afternoon all, Got a bit of a strange one (by my usual standards anyway). Job is a large barn conversion, done years ago, there's loads of work to...
