- Reaction score
- 10
Hi all, I have recently carried out an EICR on a big house and am struggling with coding on quite a big issue. The main tails & earth's are connected into Henley blocks, then looped into 2 separate consumer units right next to the service head/meter etc. Then there is a 3rd set of tails which go into a 100a DP main switch. Connected to the load side of the switch is a 16mm Swa which runs underground into another Consumer unit in an extension of the house. There is no connection from the MET to the swa feeding this 3rd consumer unit, hence there is no main earth connection at this board. The problem is, although it is a relatively simple fix, I have been asked to only do a report & not touch any remedials yet.obviously I know the issue needs resolving as a matter of urgency, however, as far as reporting it I am struggling to find a reg. number and code. Any help much appreciated
