Discuss EICR supplementary bonding query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys
I am doing an EICR for a friend - older build all current works pre-17th edition
have failed the bathroom - no supplementary bonding on pipe work and there is not RCD present
i am going to give a C2 for supplementary bonding and C3 recommending to install RCD
By doing this I am only upgrading to the 16th edition regs.
Would this be satisfactory or should it be upgraded to the 17th edition.
Normally I would recommend upgrading to 17th edition but I'm trying to keep the cost down for them.
no. give it a C2 for " no supplementary bonding and no RCD". that is all you need to do. in comments, just state that the fitting of a RCD may negate the need for supp. bonding.
Does it need supplementary bonding ?
Have you tested to see if it needs it ?, bear in mind supplementary bonding may be made outside the room.
Agree with what you've written and normally this is what I would do
as we're trying to keep costs down was going to install the supplementary bonding myself and log the work as C3 recommending installation of RCD
my worry is that this will be restoring the installation to 16th edition regs and although it was installed ages ago not sure I'll be able to leave it like that
As already said, supp bonding may not be needed depending on the test results achieved. If this is the case you'd only be dealing with the lack of an RCD for additional protection which would be a C3 as you have stated.
Reply to EICR supplementary bonding query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just had an EICR done and C2 (dangerous) applied to 3-way consumer unit which is exclusively for 3 x Storage Heaters. Pic below. Yes its plastic...
Hello. Non-electrician here. Failed an EICR yesterday as the electrician graded my consumer unit C2. Why C2 and not C3? He didn't say (and still...
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
Hi everyone Sorry if it's a repeated question tho. Agents followed me a failed visual EICR which has C2 for lack of RCD on cooker circuit and...
