- Reaction score
- 8,188
But only if the manufacturers instructions say it’s ok because many don’t allow top entry
Yes, should have added that. Ta muchly
Discuss Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
A few heads are better than oneYes, should have added that. Ta muchly
that's what the hydra headed m-i-l says.A few heads are better than one
Post #15 has the manufacturers instructions. Top entry is suitable, but it's not designed to be knocked out, you need to use a suitable tool to cut it out, and it makes note not to use pliers to do itThe thing that would worry me is if there is a place for suitable cable entry, it is usually a removable piece, that shower top has been chewed away. If you were simply bringing a cable in the correct top entry point, a drill or in this case whatever he has buthered it with would not be needed.
Edit
Ask your landlord for the Part P notification and also the EIC, not only of this but of the mains board change.
Also if safe to do so can you take a picture of the mains board. Leave the cover on, just the surrounds of it.
That is a dog **** install at best
Oh, Not pair of garden Secateurs then?you need to use a suitable tool to cut it out
It doesn't imply they're not 'suitable'...Oh, Not pair of garden Secateurs then?
Reply to Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
