Discuss Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
That's a terrible job. does the sparky have any sort of training or licence other than a dog licence?
Was there any sort of certification supplied on completion?
Have they been paid?
Totally non compliant with any sort of regulation and potentially dangerous. I would advise you refuse to use it. A health and safety complaint to whatever tenancy protection agency is in order here.
I'm a New Zealand Electrical Inspector who has worked in the UK, as I said this is dreadful and dangerous.
Interesting stuff this...I fitted a new electric shower about a year ago and was no impressed with the casing and its provisions for cable entry or water connection. It was a direct swap for a model by the same manufacturer but the new one was noticeably flimsier and although there was a "double channel" around the outer casing, the plastic knockouts were falling out by themselves...and of course the fixing holes for the back plate were in different positions. Fortunately my cable enters from the back, so I didn't have to use the knockouts. However, what I did notice was that the existing shower was really quite dusty on the top surface (tsk,tsk Mrs Pirate!) so it looks as though there was very little splashing hitting the casing...maybe just the way my daughter uses the shower, as it was in her bathroom, but she spends ages in the shwer washing her hair and is not the neatest lass around. I phoned the shower manufacturers "helpline" because I had a query about the water connection. The instructions said must come straight out of the wall, not up or down via an elbow, and the suplied push-fit connector must be used...why? The man told me it's in case the push-fit comes loose with the water pressure...really??? The case is rawl-bolted to the wall and the pipework is firmly secured too, so what could happen? "It'll invalidate your warranty, sir" was all he could say...
I connected it with a compression elbow, suitably torqued-up with my calibrated wrist...
Other models say there is no rear entry option...
Frankly, just built down to a price
The thing that would worry me is if there is a place for suitable cable entry, it is usually a removable piece, that shower top has been chewed away. If you were simply bringing a cable in the correct top entry point, a drill or in this case whatever he has buthered it with would not be needed.
Edit
Ask your landlord for the Part P notification and also the EIC, not only of this but of the mains board change.
Also if safe to do so can you take a picture of the mains board. Leave the cover on, just the surrounds of it.
That is a dog **** install at best
Edit
Post #15 has the manufacturers instructions. Top entry is suitable, but it's not designed to be knocked out, you need to use a suitable tool to cut it out, and it makes note not to use pliers to do it
Reply to Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
Hi there guys. I am working as a maintenance electrician in an office block. There are Shower rooms on some of the floors, with electric shower...
