Discuss Electrical car charging points - what do i need as an installer? in the Electric Vehicles Advice Forum area at ElectriciansForums.net
I can't see why it's so complicated, surely it's just a battery charger fixed to the wall? Well a bit more complicated, actually maybe not, it's a damn battery charger.
I don't see an earth rod next to my Duracell charger, or one that I plug in then put on the van battery?
Can someone explain who knows, why it is so involved.
its not the charging unit, its the car! when its plugged in, if you have a lost neutral on the incoming main then the car is a great big lump of live metal insulated from the ground, then if someone touches it whilst also touching a steel fence post in the garden etc etc.......u get the picture
also potential difference between earthing systems is also a problem
Whos ever been up a scissor lift and put their arm on the metal tray work and got a belt? I have!
I looked up 16a and 32a isolation transformers today for the electrical separation option.......not much change out of a grand! Class 2 external light fittings all round i think!
I was thinking about this today, and did think if it was because you could have a car isolated from the ground due to rubber tyres etc.
Makes sense nw looking at it like that, but still think its a bit over the top and needs reinventing.
Reply to Electrical car charging points - what do i need as an installer? in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
Electrical2Go - Green2go Launches for All Your Solar, EV Charging and Renewable Needs Green2Go - for All Your Solar, EV Charging and Renewable...
Hi everyone, I'm currently working towards getting qualified as an electrician and am hoping to get my foot in the door with an apprenticeship or...
Just taken deilvery of an Electric Car (Mini Electric) and so doing some research into installing a charge point. Supply is a standard Single...
4K
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
