Discuss electrical leak auto off in the UK Electrical Forum area at ElectriciansForums.net
Hello, I am going to install garden spotlights. I know from experience that theses lights installed outdoor will develop leaks to the ground or even short circuits especially when wet. Is there a device I can install such that the power automatically switches off when leaks develop?
Julian
An RCD is designed for this task.
Ask a local electrician, they should be able to provide one
They are called different things in different countries
Basic theory is they compare the live current with the neutral current and turn the power off if there is an imbalance between the 2.
If the spotlights are the correct IP rating and the cabling is installed properly and professionally there's no reason they should get wet and develope earth leakage faults.
As James says the device you're talking about is an RCD and is called a GFCI if you're in the USA.
Philippians originate from the planet Philip, somewhere in the Romulan sector. they are currently preparing for a Klingon war, but at present don't realise the danger posed buy the ever present Borg. resistance is futile. you will be assimilated.
Reply to electrical leak auto off in the UK Electrical Forum area at ElectriciansForums.net
Looking for an outdoor centre off switch (not retractive) and find myself short on options. I have a lot of Gewiss enclosures to which a centre...
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
Cathodic Protection Station with Switching Power Supply for Buried Metal Structures Benefits of the Switchmode Cathodic Protection Rectifier...
Hi There, Just wondering if anyone is aware of any devices that automatically preserve vehicle 12V battery life by breaking the circuit once the...
Hello, you all helped me out recently when we had a water leak (mostly in kitchen ceiling), and my landlord's contractor was saying the household...
