Discuss Electrician uses 1,000 volts to his advantage in the Electrical Forum area at ElectriciansForums.net
Aico Carbon Monoxide Detectors
Wilko
Hi - setting something with the intention to hurt someone else is not ok in my view, imagine if a kid just grabbed the handle?
I’m no lawyer, but this reliance on not causing lasting damage is a bit silly. Assault for example does not have a minimum measure of lasting damage, thankfully.
Here’s something from the law books :) .
telectrix
Mentor
that mentions something about set to destroy vermin. van robbers are vermin.
James
Mentor
Supporter
Love the idea,
However I doubt that setting booby traps will hold up in court as legal if someone was killed or injured.
The only thing that worries me about advertising the voltage is that people may assume that 1000v will not kill you. This can give the misconception that anything under 1000v will hurt but will not kill.
FatAlan
Trainee
Sounds like it’s just rigged to the handles. I hear that thieves are just cutting the sides of vans with angle grinders. Just add a pair of marigolds and problem solved.
James
Mentor
Supporter
It Will kill you if the shock makes you jump back into the path of a lorry.
T
The Ghost
No different to an electric fence or bird scarer and they are higher voltage 11kv so it's good for birds and beasts but not a thief, I'll have two! Anyway as kids we used to have what we considered fun, daring each other to touch the electric fence (country boy) we loved it. Nobody was harmed.
ruston
Mentor
Advent Win
And using a wet Piece of straw to get the sizzle
telectrix
Mentor
if he fitted 2 fly swatters in series, could he get 2000V? . ( N.B. for the pc brigade, i don't have flyphobia. i have nothing against flies).
ruston
Mentor
Advent Win
Those old Sparkrite electronic ignition systems could give a belt of 50 to 60 thousand volts if my memory serves .
James
Mentor
Supporter
A good ignition coil will give you a belt that hurts a lot.
Nearly as much as the pain caused by banging your head on the bonnet when you jump back.
ruston
Mentor
Advent Win
Yes , I've had a few of those caused by laziness , pulling the leads off to see what cylinder is down . Those impromptu tests are all but gone now unless it is an old classic.
Electrical2Go - Online Electrical Supplier
Reply to Electrician uses 1,000 volts to his advantage in the Electrical Forum area at ElectriciansForums.net
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Top Bottom
