Discuss Emergency Lighting within Welfare and First Aid rooms in the UK Electrical Forum area at ElectriciansForums.net
A
andybird
Can anyone confirm or deny whether it is a statutory requirment for luminaires within a Welfare and a First Aid room to be emergency fittings, or would standard fittings be acceptable if there is for example an emergency bulkhead luminaire above the door?
The Risk Assessment will tell you where EM lights, and what type are required.
If there isnt one, the Owner should be getting one done.
First Aid room - rather than egress lighting, such locations may to be suitable for continued use when the power fails, so a differnet type of fitting, or more of them to keep Lux levels at a sutiable level may be needed.
Reply to Emergency Lighting within Welfare and First Aid rooms in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
Regarding emergency lighting, does a fire exit door require an emergency light above it or can you use a sticker that illuminates?
4K
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi little lost on a question for lvl 4 design verification Can anyone guide me to any calculations or formulas Its for a 4.35m x 2.8m plant room...
